Belling fan cooker
  • #101407
    dekwill
    The top oven works but the fan is not turning and oven not hot if the element has blown will the fan not work
    #484622
    no if element blows fan will still run
    if unit has a clock check its not been knocked out of the manual position
    dekwill
    So if the fan stops working would that blow the element
    #484624
    dekwill
    it has just come back on now but the fan is rattling
    #484625
    dekwill wrote:So if the fan stops working would that blow the element
    that can happen the element would glow red because the fan is stopped, so the oven would heat. the stress of this on the element can then blow them
    i still think the first port of call is the clock or the switch
    also some belling cookers have a door switch and these can fail
    dekwill
    do you think the fan rattling could be a problem
    #484627
    is it heating now ?
