Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Belling fan oven – element stopped working?
- This topic has 13 replies, 4 voices, and was last updated 16 years, 6 months ago by
PaulStat.
September 16, 2009 at 9:31 am #48627
PaulStat
ParticipantWe have a belling fan oven, turned it on to heat up last night, after a few minutes of it being on the lights flickered and the wall sockets trip switch had flicked off.
After turning it back on, we turned the oven on and it sounds fine, but it just doesn’t get hot, it gets warm but no where near being hot.
Any ideas? I’d rather not have to get an engineer out if it’s something simple we can fix ourselves as we don’t have much money at the moment.
If someone could point me in the direction of the part I would need and some basic instructions on how to fit it that would be great.
September 16, 2009 at 9:42 am #297188kwatt
KeymasterRe: Belling fan oven – element stopped working?
Probably just the fan element that’s popped which you can usually see but easily test for continuity if required.
Most are a case of taking off the rear panel inside the oven and you should see the element.
I will need the model number to be sure, so I can check what type of oven it is and what element is fitted.
HTH
September 17, 2009 at 8:22 am #297189PaulStat
ParticipantRe: Belling fan oven – element stopped working?
Thanks for the quick response, unfortunately I have no idea of the model number as we inherited it from the previous owner it doesn’t have any markings on the front and we don’t have the owners manual.
I took the plate off from the back of the inside of the oven this morning, exposing the fan and the element. How do I tell if the element has “popped” as you put it?
Thanks,
PaulSeptember 17, 2009 at 8:33 am #297190kwatt
Hi Paul,
Find the rating plate, the model and serial number will be on that. Instruction books are useless for that for the most part anyways, don’t trust them, they lie. But it really is very important that you have that model number so as you get the correct element and also the best price as there are often alternatives.
On the element you may be able to see physical damage to it, as in it’s split or something like that. But apart from that most of the information you need should be in this article about fan elements.
HTH
September 17, 2009 at 9:19 am #297191PaulStat
kwatt wrote:Hi Paul,
HTH
Hmmm I bet that rating plate is in a hard to reach place!
Ok I’ve had a read of that article, can’t say I noticed any splits but I’ll have a closer look tonight. Part of the coil did look a bit bent?
September 17, 2009 at 9:33 am #297192don
ModeratorRe: Belling fan oven – element stopped working?
Hi Paul
The model no. can normally be found behind the main oven door towards the bottom left hand corner.
HTH 🙂
Don
September 17, 2009 at 5:35 pm #297193PaulStat
Right not sure if this is what you’re looking for or not? Found this on a sticker inside the main oven compartment just by the door. Two numbers it says
Belling 050554055
And then a barcode string
20031402776 042407008 21 01
Oh here’s a picture of the element not sure if you can make it out or not
September 17, 2009 at 7:43 pm #297194kwatt
Yup, it’s all misshapen at the back, probably toasted. 😉
I can’t track that serial number or the 050554055 number but I think the element is this one by the looks of it.
HTH
September 18, 2009 at 8:29 am #297195PaulStat
Thanks 🙂
When I google “Belling 050554055”, the results I get seem to suggest a 2000W element, the one you’ve linked to is a 1800W, will that matter?
Also it’s a freestanding oven an not built in, does this make it more tricky?
September 18, 2009 at 6:47 pm #297196Penguin45
Your cooker is a Belling 864ST, made in Italy by Merloni. THIS ELEMENT is the specific one for your appliance.
It is retained by two nuts on the rear of the casing, so back panel off for access.
Power off as well.
September 18, 2009 at 7:30 pm #297197PaulStat
Penguin45 wrote:Your cooker is a Belling 864ST, made in Italy by Merloni. THIS ELEMENT is the specific one for your appliance.
Power off as well.
Darn that’ll be a bit awkward then, thanks!
What do I do about the gas pipe going into the back?
September 18, 2009 at 8:26 pm #297198kwatt
Thanks Chris, I couldn’t track that number but I was a little pressed for time. 😉
If it’s on a solid pipe then it will be a Gas Safe registered plumber job to disconnect it.
If it’s on a flexi hose then it’s a bayonet fitting that will release easily and safely.
HTH
September 18, 2009 at 8:33 pm #297199PaulStat
kwatt wrote:Thanks Chris, I couldn’t track that number but I was a little pressed for time. 😉
HTH
It’s on a flexi hose thing, right so gas off electricity off. Must try not to blow myself up 😛
September 22, 2009 at 10:35 am #297200PaulStat
Well it’s arrived 🙂
It looks right from what I can tell, the only difference I can see at the moment is that the plate where the two prongs for connecting the electricity to are, don’t have what look like removable screws.
The one that’s currently in my oven has what look like cross head screws on the inside of the oven, though I haven’t taken the back panel off yet to check for securing nuts.
