Belling Farmhouse 110E Wiring Diagram Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Belling Farmhouse 110E Wiring Diagram This topic has 7 replies, 2 voices, and was last updated 3 years, 11 months ago by scotrob171. Viewing 8 posts - 1 through 8 (of 8 total) Author Posts April 16, 2022 at 9:21 am #100744 scotrob171Participant Hello, Can anyone help with wiring diagram for Belling Farmhouse 110E All Electric cooking range (444444148) S/N 80303303 Thanks Scotrob April 17, 2022 at 5:39 pm #482020 scotrob171Participant How Likely are Belling going to give me a wiring diagram ” Under the right to Repair Law”. April 17, 2022 at 5:49 pm #482021 electrofixModerator scotrob171 wrote:How Likely are Belling going to give me a wiring diagram ” Under the right to Repair Law”. you could try but its doubtful why do you need it ? Dave April 17, 2022 at 6:00 pm #482022 scotrob171Participant electrofix wrote: you could try but its doubtful why do you need it ? Dave Cooling fan intermitted and wanted to see the set up before going to job so I could take some useful parts with me. April 17, 2022 at 6:46 pm #482023 electrofixModerator parts seem to show a 70 degree stat and the normal small stoves fan could be as simple as gummed up fan Dave April 17, 2022 at 7:07 pm #482024 scotrob171Participant Hi Dave, Its not the main oven fan, its the one cooling electrics etc. It seem to run for hours after been switched off “Sometimes” . April 17, 2022 at 7:15 pm #482025 electrofixModerator yes assumed it was cooling fan 70 degrees seems about right for a cooling fan cut in had a few of them where the fan guard was almost blocked stopping airflow Dave April 17, 2022 at 8:19 pm #482026 scotrob171Participant Thanks for your responses, job is good distance away from me, So will order stat/fan and hope it can be repaired on 1st call out. Author Posts Viewing 8 posts - 1 through 8 (of 8 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
