belling farmhouse 911 timer fault
Home Forums Public Support Forums Help And Support Cooker And Oven Forum belling farmhouse 911 timer fault
  • #14651
    nibs1307
    My Timer has failed (according to the Belling Engineer who had all ready changed a solonoid, which was not the fault) on my Farmhouse 911 cooker. Belling say that they no longer sell a replacement part, but will sell me a new cooker (FAT CHANCE). As the cooker is only 5 years old I do not want to replace it. does any one have a wiring diagram for the timer as i`m hoping to bypass it as i do not use this facility.
    #160324
    Mark_Fixcookers
    Re: belling farmhouse 911 timer fault
    you should have 4 wires to the clock
    live (marked L)
    Neutral (marked N)
    and two wires that are very close to one n other that are connected to the clocks switching relay
    You may find that one of these relay wires has a piggy back spade connection
    Its simply a matter of connecting these two “Relay wires” together
    this will bypass the automatic switching of the clock, and hence you will lose the “automatic” functionality of the clock, it will simply always be in manual mode, no matter what the clock display states
    #160325
    WITH THE POWER OFF, OF COURSE.
    #160326
    garn
    Just Been Searching for A Timer For A bekking Farmhouse 930.
    The Thing is Ringing constantly.
    is It The same Procedure As 911 model above Relay Bypass.
    Thanks UKWG & Gogle Search.
    Garn.
