BELLING FORMAT Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › BELLING FORMAT This topic has 3 replies, 3 voices, and was last updated 20 years, 6 months ago by tonyclifton. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts September 24, 2005 at 3:28 pm #12149 tonycliftonBlocked Hi guys, got to go look at belling format cooker, main oven fan does’t ever stop runnin only way is to turn it off at wall, oven heats up fine, is this gonnna be the fan motor k/o cheers tony September 24, 2005 at 3:36 pm #148092 Penguin45Participant Re: BELLING FORMAT Selector faulty most likely Tony. Chris. September 24, 2005 at 4:28 pm #148093 tonycliftonBlocked Re: BELLING FORMAT cheers penguin, the oven is all controlled by the clock u have to press button and turn dail to set temp so could it be the clock/timer regards tony September 24, 2005 at 8:37 pm #148094 bobokinesParticipant Re: BELLING FORMAT If it’s the cooling fan that’s running, then it could be the trigger board down by the mains terminal block. Fitted one a few weeks ago, The Creda part is the same but cheaper. Bob Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
