Re: Belling Format 600XR2
kheath wrote:I think the light is controlled by a small pcb situated under the rear cover access point to the mains lead, this also controls the cooling fan staying on after the ovens been used, perhaps worth investigating here.
Also these had a habit of melting the multi way connector from ovens to control panel, causing all sorts of weird faults. This is situated under the r/hand side panel as you look from the front, at least a 12 way plug carrying the element currents!!!!
Have fun
Kevin
and the repair is a new loom, great job!
