unable to read any model numbers, this is a fairly old cooker in white.
I need a main oven thermostat, it has a square black switch unit fitted to the front of stat with 2 tags only….I am trying to match up with spares on connect site, but unable to match easily.
can anyone please help. John
They don’t always come with the switch attached. Possible ones used on the Format range include SW1099 and SW1153. If you can transfer the switch part you could get a universal type with the same temperature range as marked on the panel.
