unable to read any model numbers, this is a fairly old cooker in white.
I need a main oven thermostat, it has a square black switch unit fitted to the front of stat with 2 tags only….I am trying to match up with spares on connect site, but unable to match easily.have rand belling unable to help!!
can anyone please help. John
Wouldn’t it be a pretty standard ‘Diamond H’ stat you’re after?
Have you looked under Belling 600R on Connects site for comparison?
The equivalent pattern stat can always be established once you remove the stat and look at the code number printed on the back (e.g. 42TH11/L5 or 47TH11/L5 or 47TH10/H5 and so on…..) 😉
