Home › Forums › Public Support Forums › Spare Parts Help › Belling format element needed
- This topic has 8 replies, 3 voices, and was last updated 15 years, 4 months ago by
Steve456.
December 9, 2010 at 10:10 pm #59479
Steve456
ParticipantHi,
New user here,
Looking for a bottom (fan) oven element for an all elctric Belling Format,
Black 600mm wide
Sorry can’t find any model No or serial number, have looked all around including back panel,
Tab centres are 35mm
Height is 240mm
Width is 260 mm
It’s round in shape
Bought from currys I think
Cooker approx 5 to 6 years old,
Sorry for the lack of serial number and many thanks,
SteveDecember 9, 2010 at 10:14 pm #338377bazza500
ParticipantRe: Belling format element needed
Probably this one?
December 9, 2010 at 10:22 pm #338378iadom
ModeratorRe: Belling format element needed
The original Belling cookers went out of business many years ago, they have been made by several different manufacturers since then.
One quite common element that is Hotpoint/Creda in origin is often found in Belling cookers of this vintage.
THIS is listed as fitting certain Format models but so do a couple of other elements.
December 9, 2010 at 10:23 pm #338379Steve456
Thanks for the quick reply,
Judging by the parts list it seems a good bet and the picks look the same as mine,
Are the dimensions correct, can’t find them on the web?
Secondly I’m concerned about fitting the wrong wattage,
Thanks again,
SteveDecember 9, 2010 at 10:24 pm #338380bazza500
The exact wattage is not crucial.
December 9, 2010 at 10:26 pm #338381Steve456
OK, so I’d be happy to buy the one you suggest if wattage not a problem, how do I find out it’s size?
ThanksDecember 9, 2010 at 10:27 pm #338382iadom
Sadly if you cannot give us the correct model number then a certain amount of guesswork has to ensue. 😥
If you could post up a picture of the element in situ it might help.
EDIT.
That element is 38mm between the dead centre of the terminals and has a diameter of approx 235mm.
December 9, 2010 at 10:30 pm #338383bazza500
Approx sizes are
Overall Length 235mm. Internal Diameter Or Width 235mm. Terminal Centre 38mm. Terminal Length 45mm. Plate Width 26mm. Plate Length 65mm. 2500W
December 9, 2010 at 10:34 pm #338384Steve456
Thanks for all the help, the measurments appear to match the element I’ve removed and as wattage should not be a problem I’ll order this and give it a go,
Many thanks for all the quick help,
Steve -
