I have a Belling E641 (Model # 4444455480) Circa 4/5 years old? 3 of the 4 ceramic rings wont allow adjustment of the heat, its all or nothing. They turn on/off on demand but i cant regulate the heat. Is my assumption the ring elements need replacing a fair conclusion or??? If so any reccomendations for the best supplier or further advice would be appreciated.
Its a 444445548, likely needing regulators replacing.
But there are 2 types available
part num’ 082045800 REGULATOR energy 30ER22MHT
part num’ 082590800 REGULATOR energy MP V01SV
hi seamy
found this post of yours on google.
i have a punter with an E641 belling
masterpart are showing the part as 012590800 quite pricey. picture has a link wire.
do you know if the much cheaper 082611723 will fit/
in past i have replaced these with ego regs after working out how to wire them but i’ve lost my plan. so fitting these cheaper gen parts would be better.
thanks
keith
