Belling ID602 DW Pump?
  • #16888
    Kirk
    Been to one today main wash pump not working, no power going to it rest of appliance works, pump has a printed circuit board in it this is a Brandt unit pump is same size as the old capacitor type. Thought the door switch was faulty to start with but then worked, anyone know what the fault is?
    Thanks Kirk
    #172006
    Dave_Conway
    Re: Belling ID602 DW Pump?
    Looking at the wiring diagram the motor is controlled by the timer but I’ve never know one fail, possibly the pressure switch ?
    I would suspect the motor itself as they fail regularly, part number 32X1617
    #172007
    Kirk wrote:pump has a printed circuit board in it
    Big Askoll? Doomed to failure…………
    Kirk
    Re: Belling ID602/2 DW Pump?
    Thanks both of you but the other problem is I have in stock 32×1617 £46.58
    but it is not the same, housing is but motor isn’t is it inter changeable? stoves gives me a part number STV082613062 £127.85 but no picture. My worry is why I was getting no power to it?
    Serial number 3 12 04058
    Thanks again Kirk
    #172009
    Dave_Conway
    Kirk wrote:is it inter changeable?
    Yep, that’s the replacement motor as supplied by Brandt, they describe it as a “kit” so there may well be some mounting changes.
