I have checked everything regarding the water supply and all seems OK. Last time we tried to use the machine we gave uo after 12 attempts as E1 appeared each time.
I have taken the side panels off and have seen, at the rear right hand corner where the water supply enters what I can only describe as a plastic tub (about 3″ dia and about 4″ high). Water entering the machine goes though this after going through a blue coloured plastic piece on the side of the washer body.
In the tub is an orangy coloured gooey substance and I wondered whether it could be fat and if this was reducing the water pressure.
If it is fat (or similar) how can I remove this please ?
