Hi All!
Got an odd one with a Belling IDW450 Dishwasher. 2 Days ago it was showing an E4 code, so I pulled it out, tipped it over 45 degrees to empty all the water out of the tray, checked the outlet hose was clear (it was) and hey presto, it worked again.
It worked all day yesterday absolutely fine, then this morning it was showing an E1 code with water pooled in the bottom. I pulled it back out again, removed all the water, cleaned everything, checked the water inlet hose was piping water through and it is, then ran a few 30 minute cycles. Every time it get’s to the last 6 minutes then stalls and shows the E1 code, and there is warm water pooled in the bottom…
Any ideas would be much appreciated,
Jon
