Been to a Belling IDW 603, god knows who makes it but the outer door fitting is identical to a Bosch but thats where the similarity ends. Think it has a blocked drain pump but cannot see anyway to access it, every other part is easy to get to but not the drain pumop. Assume its a cavity off job but seems a lot of work for a piece of glass in the pump, anyone done one?
Seamy wrote:Similar to a New World, think you have to take off side panel to get at it.
if only, both sides off and still unable to access it as its dead centre rear. Bottom is sealed as is rear. can only assume its a Bosch style top lot off the base job.
yes take off both sides and tip machine on it’s front, then remove screws that hold base into position, they are at the rear. The base (complete with feet) drops down without any major obstructions… Can’t believe it, all that to get to the drain pump, madness.
