Belling IDW603 dishwasher
Unable to programme the dishwasher.
On power on LED displays 2 reverse L in the 8 seg displays.
Apparently the display should read “Programme selection” then use the select pushbutton to select prog.
No warning lights for low salt / rinse aid etc.
Programme selected led’s do not illuminate.
Unabel to get to run to check filling / draining etc.
Almost certainly PCB corrupted. P/no 516020201, spares@ukwhitegoods.co.uk will get one for you. Be absolutely certain that this is what you want, as they’re pretty expensive.
Hi Penguin
Many thanks for te reply. Possibly better leave the repair for now until funds are available then or get an engineer out to make sure it is that before proceeding.
Thanks again for teh info .
