Belling IDW603 Dishwasher
  • #44723
    squadman
    Been to the above appliance and the customer says that it went through the wash cycle but when they came back to the appliance although it had washed and dried the wash load the dual numeric display was displaying two L L but both letters are reversed basically letters backwards !
    Have had the module out but nothing obvious and this appliace looks like either a Diplomat or Smeg, the Re-Circ pump is located front left. Have any of you had any experiece with these and any idea what the fault code displayed may mean ? The customer has a user manual which shows the error codes but they are all E11 E12 etc etc, nothing that matches the problem I have. Also who would do spares for this ?
    Any help much appreciated !
    #282081
    Re: Belling IDW603 Dishwasher
    squadman wrote:it went through the wash cycle ….it had washed and dried the wash load
    So does it still work? Or not? If it does still work, what are they like in the south east? If not, what’s happening?
    Mike.
    #282082
    Um, are you helping here, Mike? The other current IDW603 thread suggests that this is some sort of Fagor-Brandt machine. We don’t seem to have any info on it. Random symbols would suggest some sort of corruption issue, but we’ve no way of knowing for sure.
    Belling spares are throug Glen-Dimplex.
    Penguin45 wrote:Um, are you helping here, Mike? Chris.
    I’m doing my best but with no symptoms to go by, it’s tough. Masterpart list 160 parts for this model, Connect 49.
    HTH.
    Mike.
    #282084
    Ok, the 160 Masterpart part numbers are all Merloni/Servis, so I’ll stand by the corruption issue – the symbols described don’t match anything that we know about.
    squadman
    Guys, the diswasher does not function at all, it displays those symbols but there is no pump or fill, nothing its just sitting there dead.
    Going back through the search pages I was starting think it may be a Servis machine as it looks simliar.
    The machine appears to have completed its last wash cycle and then when the customer came back it had those two reversed LL letters on it !
    Thanks for any input you can give 🙂
    #282086
    Have you thoroughly checked the door microswitch? Door wiring? Module is £115+ trade @ Connect 🙁 , though in stock which suggests they expect to sell one occasionally. QER
    http://www.qer.biz/prodRepairsModel.asp
    lists this model as a possible repair at £29 but with 67{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} success rate only.
    Mike.
    #282087
    squadman
    Mm I have checked the Door Microswitch first ! had the PCB and examined it, it looks fine. I have not checked the wiring loom where it passes through the door that will be my next move, other than that I am not sure. The module is about £150.00 retail plus labour and I don’t really want to order a module down at that price.
    Hopefully it may be fractured door wiring .
