Hi, I keep getting E5 showing up when the dishwashers been on for a while and no water appears to be coming into the machine. Any help with sorting what the problem is or what the code means would be very much appreciated.
Surprisingly enough, E5 is no fill within the specified time. Basic checks are water supply on and fill hose not kinked closed.
Technical possibilities are failed inlet valve or computer lost its marbles. If you are not confident using a test meter, please seek pro help. Check Directories or Repairs@ for a UKW engineer in your area.
Power off if you wish to investigate further. :plug:
