Belling IDW603 Integrated D/W Hinges
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Belling IDW603 Integrated D/W Hinges
  • #57952
    delahart
    Hi all,
    I can see from the posts that this topic might have come up before but not sure of the conclusion. The door has dropped and the right hinge has a plastic lug attached and I presume (not removed from cabinets) that there is a string to a spring. The customer found bits of plastic from the left side. In the diagram on Connect and supplied by Belling that there appears to be no string. Is this a modified hinge and spring and presumably I have to get both items. Also do I need to get right hand to match??
    Delahart ❓ ❓
    #332783
    smeghead
    Re: Belling IDW603 Integrated D/W Hinges
    Pretty sure part u need is Door Cord – Electrue no.5031687921154 @7.77
    Similar job to the Hygena doors. Fit left & right though.
    Clive.
    #332784
    delahart
    Thanks for the info, spot on with the cords.
    Delahart.
