My Belling integrated dishwasher has developed a fault, no error codes come up, basically what happens is whatever wash I put it on, the machine drains any residue at the start as usual, starts to fill up and then stops it then clicks several times and it is then silent, after a minute or so it clicks again twice with a slight pause between and carries on like this for a time before it goes silent.
Update on above:
On looking at this again on one occasion I used program 6 the machine did as above but then a few minutes later it put in more water and repeated this several times before it came up with error cod E6 and was beeping in succesions of 3’s, it only did this the once I have tried it again and it is only doing the original stuff at the top of the page.
Also just touched the motor and it is very hot, to hot to keep your hand on it in fact
the manual says this being done at end of cycle is the filters are blocked or a pot is placed upside down, there is nothing in the machine and the filters are clean (i’m taking it that there is only the filters in the inside of the machine and there are no other hidden ones)
