belling integrated dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries belling integrated dishwasher
  • #61414
    petalpop
    same as baumatic
    was showing E3
    we changed the element and all seemed ok
    customer tells us that machine is fine and heats on eco wash
    but there is no heat on the other programs
    i will be calling back friday to check machine and get model etc
    anyone got any ideas please
    #346021
    Seamy
    Re: belling integrated dishwasher
    Likely is underfilling & not enough water pressure to keep heater pressure switch on for the heating cycle.
    #346022
    petalpop
    how comes it heats ok on the eco wash though
    #346023
    Seamy
    Have got E3 problems on Belling Int’ IDW604s solved by tweeking the screw on pressure sw’ a little to fill more water. Having tried new heaters, pumps, p.c.bs etc to no avail, unless its a warranty job it’ll cost a fortune trying parts.
    Perhaps on eco’ it heats for a timed period only.
    #346024
    keithwilliams
    if you can be bothered, you could bypass the switch and try it. see what happens. after all this switch is basically an added extra over the indesit that its based on. not that i’m suggesting that you leave it bypassed.
    #346025
    petalpop
    not sure about bypassing the switch
    which way do you turn the screw and by how much to let it fill a little more
    #346026
    keithwilliams
    i don’t mean the pressostat.
    i’m talking about the microswitch thats in the hose from the spray pump. pink wire in from pcb and pink wire out to the heater. put the pcb wire directly onto the heater and see if it heats on the cycle that otherwise isn’t. then you will know that its either the switch or as has been said too low a water level. also without fiddling with anything, you could also pour in some extra water in tub after its filled, then try it.
    #346027
    Micky 32
    I have always felt water was a little low on these.
    #346028
    petalpop
    right that makes sense but
    if it does need more water what can be done to solve it
    as when i go back to it i would like to know i can sort it as
    it is an absolute pig to get out
    you know the ones
    fill hose too short
    lead threaded through 2 cupboards etc
    #346029
    sce
    Yes i had this problem of no heat on whatever prog i set it on.I by passed the heaters m/swt-the part you mention,and tried it -now works fine on all programmes.I didn`t mess about with the p/swt however.I told the customer on no account do you accept the repair if it is still wrong-never phoned back,so presume it worked out ok.
    #346030
    keithwilliams
    thought id revive this thread.
    got a new world dishy coming up e3 and again not on eco. messed on with it at home and finally worked out that a quarter turn on pressostat allows just the right amount of water in.
    thought what a clever boy i am until ive just noticed that Seamy does this already.
