belling integrated oven is tripping RCD
Home Forums Public Support Forums Help And Support Cooker And Oven Forum belling integrated oven is tripping RCD
  • #37097
    gr1688
    Hi all,
    I have a belling integrated fan oven /grill that is tripping RCD in my consumer unit, when I put the fan part on everything is okay, it’s when I put the temperature selector the RCD trips and only when I put it to the grill part I am guessing I probably nedd a new element for the grill?, any help appreciated
    not sure of the model no. but could be any of the following 250,251, 252, 272 or 271, these are all the numbers on the manual
    cheers all
    #253503
    Re: belling integrated oven is tripping RCD
    Not enough to go on, I’m afraid. 250, 251, 252 all have different grill elements for a start.
    Check around door framing, failing that you will have to remove the oven from the housing and look on the back or top.
