Belling microwave M395TCCS combination, grill not working
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Belling microwave M395TCCS combination, grill not working
Viewing 1 post (of 1 total)
  • #48679
    internet
    I have had this brilliant little microwave for years and it has never faulted once until now.
    The grill lamps dont light up which means of course the grill doesn’t work or the combination although the microwave still works fine.
    I have unplugged the machine and removed the cabinet. It was a simple enough job lifting 2 bent securing clips that secured the cover holding the lamps.
    There are 2 lamps in there and I just think its a bit odd that both should fault at the same time and decided to ask you very kind chaps for any advise you can give.
    It looks easy enough to disconnect the lamps but I would’t have a clue if they are working or not and if something else is creating the problem before I go and buy replacement lamps..I would be grateful for any advise,, thank you in advance.
