Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Belling, no grill or hotplate?
- This topic has 8 replies, 5 voices, and was last updated 15 years, 8 months ago by
iadom.
August 3, 2010 at 10:00 am #56251
ModeratorA Turkish made machine. I think the model is a 335.
Numbers on back are AWO 232 4269202 06 A….with solid hotplates.The grill and the front, left hand hotplate are not working, customer is certain they both failed at the same time. 😕
The grill element is perfect, the solid hotplate appears to check out OK.
The thermostat control for the grill is switching on & off.All of the contacts inside the hotplate control are switching correctly and there are no other obvious signs of any wiring problems.
First time I have ever seen one of these, any suggestions welcome. 🙂
August 3, 2010 at 10:35 am #326701bazza500
ParticipantRe: Belling, no grill or hotplate?
Problem with the terminal block melting on these and one of the feeds goes open circuit.
August 3, 2010 at 10:38 am #326702iadom
ModeratorRe: Belling, no grill or hotplate?
Thanks for that Bazza, I will check it out.
I don’t suppose anyone has a wiring diagram for one of these?
PS, is it a BEKO ❓
August 3, 2010 at 12:19 pm #326703wilf
I’ve had this, its a cut out. a microtemp clamped to the back of the grill cavity conversion kit ( stat) bek210110544 did the job
check the model number against this part just to make sure it is the right part
wilf
August 3, 2010 at 3:41 pm #326704iadom
Sounds good Wilf, I will check it out. 8)
August 6, 2010 at 2:27 pm #326705iadom
Spot on Wilf, new cut out did the trick. :tup:
Strange why it is only wired into the grill and front left hotplate though. :con:
August 6, 2010 at 2:31 pm #326706electrofix
come on its a Beko does anthing they do make sense 😆
August 6, 2010 at 3:14 pm #326707wilf
glad to help
wilf
August 9, 2010 at 10:14 pm #326708gandh1
also for future reference, most the stoves/bellign fan ovens have a overpriced gdha element in them, directly sourced from beko.
for recent 50cm f.s belling/stoves fan ovens use this element 462900010 -a tenner vs £25!!
