Belling Noisey Fan
  • #24397
    Angler
    Guys,
    Our Belling Optima 590 has developed a ‘squeak’ when the fan oven is turned on. The oven warms up ok and controls but makes a squeaky noise.
    I’m guessing the fan bearings are on the way out.
    How easy is to replace the fan and can you supply ?
    Cheers
    Roger
    #201955
    Re: Belling Noisey Fan
    Replacement only viable long term solution – after the squeaking stage, it’ll start to slow down, then you risk losing the fan oven element as well.
    If you’d post up the full model number, we should be able to identify which motor is required.
    Power off if investigating.
    Angler
    The label that the info on it (located on the top oven door edge), is virtually illegible, the info I can get off it is:-
    Belling
    Model 590 BR(or N)
    Volts 230v
    Serial No. 99 00004
    Power 4.252kW 4.630kW
    Hope this is enough!
    Roger
    #201957
    Dave’ll know what the price/availability is on spares@ukwhitegoods.co.uk and be able to get the part if it’s gettable. 😉
