Belling or Beko Thermal fuse Belling BE335WH
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Belling or Beko Thermal fuse Belling BE335WH
  • #59704
    maltheviking
    Can someone clarify the parts for the in line thermal fuse (microtemp 142deg)on these Beko manufactured cookers please?
    I have been to the above model BE335 where the inline fuse had blown. The customer produced a thermal cutout that he bought from a shop in his home town, Beko part no. 210110544 totally different to the micro temp except it has the same mounting bracket.
    His part did not have any temperature marked on it.
    Is this a part that superceds the micro temp?
    Connect are still listing the micro temp as 5045170721022 😕
    #339286
    trotter
    Re: Belling or Beko Thermal fuse Belling BE335WH
    I am sure that the thermal fuse replaced the microtemp although don’t know the part number!
    The good thing is that if the fuse blows again it is not YOUR part so you don’t have to guarantee it. I have heard of some nightmare scenarios with these where they just keep going within twelve months.
    A bit like neff elements I guess
    #339287
    geoff1
    The inline thermal fuse has been replace by a round thermal cut out on some cookers.
    Depending on model they sometimes need a kit which includes wiring and round thermal cut out.
    The replacement fits on the right hand side of chassis not on the oven back with the bracket pointing downwards. (screw at top)
    If you let me have your email addrees I will send you some stuff
    Geoff
    #339288
    helo_75
    that part you have 2101105544 is the correct part, just rewire it and mount it on the plate on the top right of the cavity
    much easier than having to change the old inline fuse
    #339289
    maltheviking
    Geoff PM on it’s way thanks to all
    #339290
    geoff1
    On way
    Geoff
    #339291
    maltheviking
    Thanks Geoff
    On looking through the info I came across part no. 4410101001 which is cutout and wiring. I presume that this kit will cover for both top and bottom cutouts, am I right? 😕
    #339292
    geoff1
    Cut out is the same for top and bottem oven
    Geoff
    #339293
    A1engineer
    4410101001 is the most recent one for most beko cookers they keep changing the part number :rolls:
    very common on the d531’a etc complaint is usually back right ring and oven not working on inspeciton you discover no neons work.
    HTH
    Kev
