belling XOU70FP/XOU90FP
customer has had a look at this oven themselves but can’t fix it.
so any heads up tips would be good before i go.
the customer said the oven is shutting down when it gets hot and won’t come back on again until it cools down , he has changed the cooling fan because it seems to be running very slow, which makes sense to be fair.
he hasn’t measured the voltage at the fan but i suspect the problem will be in the control of the cooling fan.
Is there a PCB controlling the fan motor? or is there any common problems with them i should be looking for?
any help would be appreciated,
cheers.
john
