hi guys,
belling built in double oven 592BL 38 100144 (about 18 months old)
customer complained that the oven tripped the electric and now the M/O lamp in the oven doesn’t work.
went out and lamp holder contacts had burned out and caused an earth fault, no problem, fitted new genuine holder and off i went. called back 2 weeks later, exactly the same problem,so fitted new holder again U/G, is this a common fault on these?or is something else causing it?
one week later the customer says the M/O stat isn’t working correctly,she says it wont cut out and burns the food.i went out and it seemed fine right upto 230deg, are they prone for intermittent stat faults?
can anyone give me part no. for main stat. incase i need one?
thanks.
john
