belling oven stat
  • #44324
    kevinlewis
    The following paragraph is from a previous post I found from another engineer. I’m in a similar position. My customer has a Belling model 623 gr 2. original stat is Diamond H 47THC3/230. I have also been told that 082604989 is now sub to 082620851 which I believe is an EGO stat. Any help ie conversion wiring diagrams appreciated.
    PostPosted: Fri Oct 31, 2008 3:27 am
    Have purchased a new thermostat to replace the old faulty one on theis oven.
    The part number I was quoted was 082604989. Ordered one and was sent an 082620851 instead. Have contacted the suppliers who say its a universal stat and will replace the original, it just looks different. Plus the spade connectors are in different places. I wired it up where I thought logically that the wires should go, switchd oven on and tripped out a circuit breaker.
    So something clearly isnt correct!
    Can anyone tell me the correct wiring for this stat please. Many thanks.
    #280653
    kevinlewis
    Re: belling oven stat
    I could see from previous post that other people had struggled with this problem in the past. Perhaps it is very straightforward but I could not find out, even from Belling, which stat would be supplied.
    Decided to order the genuine Stat from Belling/Stoves/Dimplex and take it up with them if there is a problem fitting it.
    #280654
    kevinlewis
    A two connection stat arrived. part number 082604989. I presume that you are meant to unscrew the selector/ changeover switch from the front of the original and replace it onto this new stat.
    In the past very similar British type stats were supplied complete with selector.
    #280655
    kevinlewis
    THE NEW STAT’S SHAFT WAS NOT LONG ENOUGH TO TAKE THE SELECTOR SWITCH. JOHN DONALLY AT STOVES ASSURED ME THAT IT WAS THE CORRECT PART QUALTEX HAD SENT ME. HE SUGGESTED THAT I ORDER THE SELECTOR SWITCH…
    I GAVE UP TRYING AND THE CUSTOMER ACCEPTED A DIAMOND H 47THC26/230 WHICH I HAD ON STOCK. A WEEK LATER AND SHE IS HAPPY WITH THE RESULTS.
    HOPEFULLY THIS SAGA IS OF HELP TO SOME POOR SOD WHO GET INVOLVED IN ONE OF THESE IN THE FUTURE.
