belling oven xou117 is my customer deluded?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries belling oven xou117 is my customer deluded?
  • #44491
    neilsukwg
    Had a phone call about oven that heats, according to my customer to about 75 degrees and no hotter. Said she managed to cook sausages but took an hour or more?
    Am i right in thinking this fan oven has only one element, if so what could the fault be?
    #281160
    bzz67
    Re: belling oven xou117 is my customer deluded?
    if the fan is not running correctly the heat will rise from the element, and the capillary above will get too hot too soon and will switch the themostat off. this will give you low temperature.
    #281161
    boselecta
    Has the fan motor seized?, that would explain it. . .
    #281162
    deltra
    faulty thermostat ❓
    #281163
    squadman
    whenever I get a tempreture related issue unless the cause is obvious I always carry out a temreture check to varify the exact tempreture. Like has been said cant be too many things causing these type of problems.
    #281164
    neilsukwg
    Thanks all,
    only askin before i go because don’t get much call for cookers.
    The reason I wondered if my customer was deluded is because I never come across a oven behaving like this before. I though maybe the fan blowing air around the oven may have given the illusion of warmth to someone putting their hand in?
    Neil
    #281165
    Also possible are partly burnt terminal and intermittent discontinuity 8) within element.
    Mike.
    #281166
    Seamy
    Have had this a few times with appliances that use selector switch and thermostat mounted on the back, if thermostat is dislodged with its shaft coming out of the the back of selector switch.
    Can happen if customer turns selector switch wrong way.
    #281167
    trotter
    Not sure of this model…..BUT does it have a “Fan” element i.e. circular element around the fan?
    went to a bosch recently that had a fan …..but only a top and base element. The top element (and grill) working fine but the bottom element was open circuit. The oven was getting warm but not hot!
