Belling Platinum DB3 Oven Wiring Diagram (02002012)
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Belling Platinum DB3 Oven Wiring Diagram (02002012)
  • #99036
    jontymox
    Good afternoon everyone,
    Wondering if anyone has a wiring diagram for the above dual fuel small range oven?
    In a nutshell, the small oven is randomly switching itself on and I have traced the fault to the selector switch.
    Alas, the part is obsolete and unavailable.
    My customer has asked if the above section of the oven can be “switched off” at least for the time being.
    I said the easiest way was to switch the oven off at the main switch, until required, but they would rather not do this!
    I’m not sure if disconnecting certain wires etc would affect other parts of the oven, or whether it would be recommended/safe?
    jonty
    #474779
    disconnect one of the stat wires as i assume since the grill part of this unit it will have to be sacrificed too
    you will struggle for diagram not only is it old but the beling tech website has been out for months
