Re: BELLING SLOT IN COOKER MODEL 633GR.
franz wrote:I would check that the circuit breaker at the main board is large enough to handle the current. It would be o.k. when either the oven or grill was on but may not be able to cope with both at the same time.
Franz
Would be my first point of call to check also..Find out what the 0ven amperage is together and check the circuit breaker for the fuse rating for the cooker circuit.You can apply diversity on cooker installs, but if a heavy load is on at the same time, then it can cause nuisance tripping sometimes if the circuit cannot handle the full load.This would not be a fault on the cooker at all,that’s if this were the issue.
