Belling Synergie 50/50
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Belling Synergie 50/50
  • #8878
    becks
    I have just moved into my first house.
    There is a built in Belling Synergie 50/50 double oven which unfortunately was very dirty when I moved in.
    After cleaning the inside I noticed that there was a streak of dirt between the two panes of glass and in my wisdom I decided to remove the front piece of glass which propmtly fell on the floor smashing into lots of little pieces.
    Can anyone tell me whether it is possible to get a glass front?
    I can’t find and serial number on the oven and there is no manual – help please.
    thanks Becks
    #130890
    Re: Belling Synergie 50/50
    Shouldn’t be a problem (bet Posh was mad with you though eh?) 😀
    Give us the full model number and we can sort out the part you need 8)
    becks
    thank you for the very quick response! 😀
    Apologies for being dense but could you suggest where I might find the model number – is it going to be printed on the oven somewhere? 😳
    #130892
    Dave_Conway
    It should be around the door(s) somewhere Becks
    #130893
    becks
    Slight problem – have located stick on oven (where the seal is) but half of said sticker is missing which I presume contains the relevant information.
    Is this a terminal problem?
    #130894
    Dave_Conway
    It does contain the information yes but it shouldn’t be terminal.
    So far we know that it’s a Synergie, which I assume is a built in double oven, what colour is it ? Are both ovens exactly the same size, which door is broken, upper or lower ?
    I’ll try and narrow it down a bit if you can answer those for me but I may be back with more questions afterwards 😉
    #130895
    becks
    Yep is a built in double oven.
    It has two silver strips down each side and the handle is encased in the glass (or at least would be if there was any glass) which is in the middle.
    The doors look to be the same size but will check at home tonight and will confirm.
    It is the lower door which is broken
    thanks
    #130896
    becks
    just had a thought 😮
    I could take a picture of it with a digital camera and send this – would that help?
    #130897
    becks wrote:just had a thought 😮
    Yes Yes….do send it though to Dave_Conways listed email address not mine OK?
    becks
    Have just looked on the Belling website and their model number XOU487AL looks exactly like my broken one.
    Hope this helps
    Becks
    #130899
    Dave_Conway
    It really isn’t worth the risk to be honest, if the glass happened to be the wrong one it won’t be returnable and most of them are up around the £50 mark.
