Re: Belt change for Vax Strech
are you sure it has a belt
does not list one for this model on Vax site
also on list of problems
Brushbar not turning
Something has obstructed the brush bar. Remove brushbar cover and clear any debris from around the brushbar itself
Recline the machine until it is lying flat on the floor
Press the brushbar reset button (located on the side of the machine) 3 times
Press the power button to switch the machine back on
The green light should now display and the brushes should be turning
no mention of a belt !!
