Belt Drive Replacement Whirlpool AW 7814 AL Dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Belt Drive Replacement Whirlpool AW 7814 AL Dryer
  • #54004
    be4con
    I’ve ordered a replacement belt but could do with some tips on replacement.
    Is it best to approach from the front or back in this particular model? All the online advice I’ve found for generic Whirlpool drive belt replacement suggests the front is the way to go but they all refer to US models.
    Many thanks in advance.
    #318012
    Re: Belt Drive Replacement Whirlpool AW 7814 AL Dryer
    AWZ7814AL…..
    Remove plug, lid, outer rear cover and inner rear cover. Remove drum, left hand side panel (from the rear), lower cover from the motor and fans and the front fan. Fit new belt around motor shaft. Replace fan and covers. Fight drum back through belt. Refit panels as above. Before fitting rear outer cover, align belt and fight onto tension pulleys.
    Make a note or take pictures of the position of all wiring before starting – we’re not allowed to sort out that kind of mistake.
    Allow Sunday for the job and retire to the pub afterwards. Contemplate that it might have been so much simpler just to ask your local independent repairer to do this for you.
    be4con
    Sorry yes AWZ7814AL, that was a small typo.
    Hell, that sounds like quite a trial. On every dryer model I’ve found instructions for online it sounds like such a simple task. I even found a You-Tube video where the chap completed belt replacement in his Whirlpool dryer in 14minutes!
    I’ll give the local engineer a ring and get a quote. I feel fairly comfortable technically speaking doing this but I’d rather not give up an entire day and it sounds like there may be a fair amount of swearing involved 🙂
    Thanks for the advice.
    #318014
    whirlpool
    hi its realy easy to do just remove the back and hang it over the left hand side, remove the conveyour and hang that over the left hand side , no need to take any wires off, remove the rear fan cover, remove fan and inner cover pop the belt on and reasemble
    #318015
    Nope, condensor, demolition required. Vented dryer is under 15 minutes.
