Belt for Hotpoint TS12
  • #17032
    hachiroku
    Thanks to advice elsewhere here (timing knob), I managed to get in and conifrm my suspicions, the belt has broken, but I’m having some difficulty finding the right replacement belt.
    It’s a TS12P, Serial 60102100.
    Thanks 🙂
    #172652
    Dave_Conway
    Re: Belt for Hotpoint TS12
    Knowing Hotpoint’s serial number and date code system ther’s an easy way to tell the 2 different possible belts for this model.
    On is tensioned by a spring loaded pulley next to the motor, the other is a stretch on belt with no pulley.
    Let me know and I can sort one out easily for you 🙂
    #172653
    hachiroku
    It’s the spring-loaded pulley type 🙂
    #172654
    Your in luck, that is the easy one to fit, part number 1741117. Send e mail to spares@ukwhitegoods.co.uk to order.
    There should be two pulleys BTW, 😉
    #172655
    Dave_Conway
    In that case clicking HERE will take you to the correct one 😀
    #172656
    Dave_Conway
    :wave: 😀
    #172657
    hachiroku
    Yep, two pulleys spring loaded off each other, tensioning the belt around the drive… spindle… bit.
    anyway, belt orderd – Many thanks 🙂
    #172658
    M600
    Hi just stumbled on this Forum & Thread,i have the TS12 with a snapped belt BUT my one is the stretch belt 😯 is it the same part No as the other or a different one??
    Cheers
    Ian
    #172659
    The belt you need is a 1702342. I cannot see it in the shop but an e-mail to spares@ukwhitegoods.co.uk should do the trick.
    Very difficult belt to refit.
    #172660
    M600
    Cheers for that,a great help
    Hope i can get it on ok 😀
    Ian
    #172661
    You will be convinced that you have been given the wrong belt, it is a very tight fit and indeed the Hotpoint engineers have a special tool to aid refitting. It is possible to fit without this tool, but if you get stuck try the link in my sig to see if we have someone in your area who can help. Plug out at all times of course. 😉
