Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Belt replacement Ariston A1636
- This topic has 6 replies, 4 voices, and was last updated 12 years, 7 months ago by
Bigonabianchi.
August 16, 2013 at 11:48 am #76707
Bigonabianchi
ParticipantHi
The spin cycle stopped working. I removed the lower back panel and the belt fell out, So I guess that’s the problem. There is no room to access the drum etc from that small rear panel and I cant find a way to remove the back panel entirely. So my question is how do I gain access to the necessary bits to replace the belt with a new one?
Thankyou for any help.
August 16, 2013 at 1:39 pm #399498Martin
ParticipantRe: Belt replacement Ariston A1636
You remove the top panel, place the belt on the drum pulley (fit a cable tie on the belt to hold it on the pulley). At this point we use a special belt tool to stretch it over the motor pulley. (Not got one ha? Try a length of steel tubing) once belt stretched onto motor pulley cut the cable tie off and viola! 😀
August 16, 2013 at 1:47 pm #399499Bigonabianchi
ok…apologies for replying to own post but I fixed it and thought id post up the how here in case it helps others.
I took off the top panel/lid by removing the two rear screws and giving the front of the lid a really hard thump from the front towards the rear at about 45 degrees. Finally it came off.
There was then just enough space to reach down to the drum wheel.
The belt is a tight fit so I put the belt around the motor spindle first, then 3/4 around the drum wheel and turned the drum wheel so the belt fed itself up onto the wheel. Just the same technique as fitting a bicycle chain onto the front cog wheels when it has come off.
The machine is now spinning.
Cheers.
August 16, 2013 at 2:13 pm #399500Martin
If you haven’t replaced the belt then chances are it will come off again sometime soon. If the drum bearings are noisy and brown water stains on the rear subframe then the belt will come off the first wash you do.
Fingers crossed that non of the above applies.:D
August 16, 2013 at 2:27 pm #399501Andy jones
If you do replace the belt soak the new one in boiling water for a few minutes. Makes fitting a lot easier
Sent from my iPad using Tapatalk HDAugust 16, 2013 at 2:40 pm #399502Bigonabianchi
Thanks guys. Yes the belt just came off again and I noticed a thread has torn off it..so I’ve ordered a new one…at least when it comes ill know hoe to fix it.
August 18, 2013 at 12:32 am #399503madangler1
Also make sure the pulley is not loose 😉
