Bendix AW1002W fault code
  • #60673
    DDDave
    Would anyone have a fault code list or link for this please. I cant find one listed here. The fault code I am getting is 4 Red 3 Green.
    Thank you.
    #343186
    Re: Bendix AW1002W fault code
    have not got manual for 1002 model but have for 1001
    assuming 4 flashes end of cycle light
    3 flashes start pause light
    fault code 43 = from lux manual
    Example: Alarm E43 (problems with the door interlock triac) will display the following:
    • the sequence of four flashes of the END OF CYCLE LED indicates the first number (E43);
    • the sequence of three flashes of the START/PAUSE LED indicates the second number (E43)
    hope this helps
    gandh1
    yeah that is e43.
    first thing is to check filter sump and pump for blockages. also inspect pecker-tolock for proper engagement
    if clear, assume interlock and probable board failure, always check board before ordering an interlock, unless you have the right one handy. saves a lot of hassle.
    if filter is obstructed, clear out, and check p/s tube too. clear e43 error code from diagnostics and restart diagnostic test.
    if you get e43 again, interlock and check pcb…
    #343188
    DDDave
    Great stuff.
    Thanks very much for the help .
