Bendix BIW 102
  • #30274
    johnnydiscus
    I have a Bendix BIW 102 914203011 washing m/c. We pulled it out of the units over the weekend for floor clean and my wife found a white connector on the floor under the m/c. It is white has 4 connections that are shorted out as 2 pairs of white wires. I have taken the lid off and they look very like the connectors on the timer module board.
    The m/c seems to work fine so I am not about to start putting shorting links anywhere that they are not supposed to go. Has anyone any idea of where it has come from or where I can get a wiring diagram for the beast.
    Cheers
    #226613
    Del
    Re: Bendix BIW 102
    Cheers
    As the old saying goes if it aint broke then dont fix it. Sometimes machines have several model variants, you will probably find that on other machines similar to yours there might be additional option buttons which most people dont bother with anyway.
    The best expert as to how your machine is working is your good lady. If she says its working o.k. then trust her judgement.
    Just as a safeguard put the connector that you found away in a safe place just in case.
