Bendix BIW125W Only Pumps
  • #47143
    neilsukwg
    Got this bendix machine that will only pump on all positions
    Lights on are Prewash and door lock
    Pressure switch does not seem stuck and there is no anti flood device.
    Is it the main PCB? or am i missing something..
    #292453
    LJDomestics
    Re: Bendix BIW125W Only Pumps
    tried pulling the pressure hose off? if u here it click if u do then try blowing down the tube itself.
    #292454
    wilf
    check the resistance of the valve if the pump is used as a ballast for the valve a short valve would run the pump.
    wilf
    #292455
    neilsukwg
    Tried the pressure switch, but not checked the inlet valves.
    Thanks, will check that.
    Neil
