Bendix Cooker CSI6001 Main Stat Mod Directions Prob?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bendix Cooker CSI6001 Main Stat Mod Directions Prob?
  • #51962
    laurenceuk
    I am fitting an ET51001/F5 main oven stat to this machine, replacing an
    ET46TH.
    `Connectections` – stat and a look at the instructions can be found under
    part No. 5031681268125.
    The cooker comes under the `Freestanding with Timer` heading in the
    instructions.
    Where it indicates timer (5) tag, this does not exist. The timer has six tags,
    1, 1a, 2, 2a, N/7 and L/8.
    Has anyone come across this anomaly before – and could you say which
    tag would be the 5 tag or has anyone a wiring diagram?
    Laurence
    #310128
    Re: Bendix Cooker CSI6001 Main Stat Mod Directions Prob?
    only diag i have for this model shows a 4 tag timer
    live
    neutral
    and two for switch contacts
    from assumption any wire that goes to the timer from a stat will be picking up a live switch wire for the automatics this is wher i would look
    you could check by installing stat get you meter between suspect wire and neutral main term. turn stat on and look at resistances if around 20 to 30 ohm will be ok
    cna send you diag but may not help if you have a 6 tag timer
    hope this helps
