bendix washing machine not spinning
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries bendix washing machine not spinning
  • #53277
    fasetester
    hi guys went to see bendix washing machine modelAW1054w no spin . checked for blockages pump brushes wiring going to pump and moter seem to check out ok the only thing left is timer give a quick check no burning or loose connections. any thoughts thanks fasetester.
    #315197
    wilf
    Re: bendix washing machine not spinning
    common fault if its 1320558107 or EMW for repair
    wilf
    #315198
    wilf wrote:common fault if its 1320558107 or EMW for repair
    wilf
    Wilf refers to the module fase OK?
    #315199
    fasetester
    are you trying to say that there is a problem with the timer?
    #315200
    Motor or heater with earth leakage can cause no spin problem. If you simply replace the timer unit, the problem will recur and require the timer and failing component will have to be replaced.
    Bear in mind that at this point the customer will become “awkward”.
    fasetester
    thanks for your reply. what resistance reading should i be looking for on the motor and the heating element or should i get a reading of infinity
    #315202
    No, no, no…
    Heater will read the usual c.25 ohms, motor 4/5 ohms across the armature and field coils and perhaps 100 ohms across the tacho (depends on the motor – tacho won’t be the problem anyway).
    You’re looking for earth leakage. Megger the element to earth and the same with the motor contacts. Nominally you can get away with 2Mohms, but I wouldn’t stake a repair on it. The electronics just don’t like it.
    fasetester
    thanks chris i meant to say when checking with ohms scale from element and motor to earth fasetester 🙂
    #315204
    fasetester wrote:thanks chris i meant to say when checking with ohms scale from element and motor to earth fasetester 🙂
    You insulation tester should be set to the Megohms scale to measure earthing resistance (i.e Motor terminal to earth that is.:wink:) not ohms fase! 🙂
    Did you get a copy of my megger test pdf? 😉
    #315205
    fasetester
    thanks martin fasetester 🙂
