bernstein 01-800270 DW overfills
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries bernstein 01-800270 DW overfills
  • #14771
    bubs
    Any advice here would be appreciated. Fixed a customers WM and was asked to look at the DW; a Bernstein 01-800270 (Servis I think). It intermittently overfills, flooding the floor. There is a pressure chamber under the filters with a 4 screw lid and an o-ring seal. This is all clean. I didn’t have time to pull it out, is there and common problem with this machine (p-switch, o-ring not sealing) or are they usually just blocked further up the pipe?
    Cheers
    Graeme
    #160760
    Dave_Conway
    Re: bernstein 01-800270 DW overfills
    I can confirm it is a Servis, personally I’ve never had one overfill on me though (that I can remember anyway).
    Loosely fitted pressure hose maybe at either end an intermittent pressure switch ?
    #160761
    goosegreen
    I have had a few overfilling and when they do the pressure S/W tube is flooded. Changed P/S (SER52000300) cured fault.
    Goosegreen
    #160762
    bubs
    Thanks, will order a presure switch.
    Graeme
    #160763
    kwaremont
    I have repaired a few of these with this fault in every case it
    was the 4 screw pressure pot lid “o” ring Steve
