We have had this fridge for five years but lately it’s been acting up!
There’s ice forming at the top back of the fridge but the rest of the fridge is definitely not cold enough.
Compressor is hot
Bottom hinge on door is broken but door still closes
Any ideas what could be wrong, how much it could cost to fix or is it time to buy a new one! If its fixable where can we get a new hinge?
Re: Bernstein 02-800950MR undercounter fridge not working
The ice build up will be system fault if your sure the door shuts ok and seals ok. The hinge is fixable but you need the system looked at 1st, it might not be repairable, you will need an engineer to advise correctly.
Thanks for your reply – on closer inspection the door isn’t sealing that well. Could this be a cause of the ice forming? If so where can we get the hinges?
