Bernstein built under freezer 900393
Home Forums Public Support Forums Spare Parts Help Bernstein built under freezer 900393
  • #9135
    I have 2 parts that I need replacing.
    1- I need to replace one of the drawers in my freezer.
    Bernstein Built under freezer 02-300393
    All the drawers are the same size.
    Please could you advise me where I can get the drawer and the cost if possible.
    2- I need to replace the small plastic clip that holds the light bulb cover
    Bersntein Chimney cooker hood 05-800358 (stainless steel)
    There is 1 clip in each light bulb cover, I need to replace 1 of them.
    Again can you advise where I can get this plastic clip and the cost if possible.
    Thank you
    Emma
    #132566
    Dave_Conway
    Re: Bernstein built under freezer 900393
    Both of these are manufactured by obscure brands I’m afraid and difficult to obtain.
    To cut out the “middle man” try giving Caremark a call on 0870 7502435 they should be able to supply, if not, then Expert Appliance Care on 0870 9099100
    Hope this helps.
    #132567
    Thank you for your help
    Emma
