Bernstein/caremark/cookers appliances model 02-800473
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bernstein/caremark/cookers appliances model 02-800473
  • #10911
    Macflame
    I have the above model dishwasher which was installed 4 months ago. The dishwasher stopped mid cycle and I had to empty the water out manually. I then restarted the dishwasher and it just kept beeping. When the door was opened the first 4 ‘m’ lights (the program select lights) kept flashing. The manual says that this is an error code but does not explain the code! Does anyone know what this code means? The man who came to look at it said it was the logic board but he wasn’t too sure.
    #143197
    Dave_Conway
    Re: Bernstein/caremark/cookers appliances model 02-800473
    This model is manufactured by Haier in China.
    At the moment there is very little information on them I’m afraid but as it’s still under warranty, let the engineer/retailer sort it out for you as they are responsible 😉
    #143198
    Macflame
    Thanks Dave. I have the suppliers sorting it out. I was just curious as to what the error codes meant. Thanks for the info on the manufacturer. It seems the Chinese are manufacturing everything these days!
    #143199
    realengineer
    he m8ty
    i know wat the problem is
    base is flooded with water possibly overflilling
    i just had the same problem today and it seems overfilling and flooding the base where a flood trips the microswitch
    ive been looking today the reason for overfilling but i couldnt found out why
    not blocked hose our anything
    in that case ive have to order a control board
    even better go and get me a whirlpool dishwasher instead
    best of luck
    btw that dishwasher is not the best one
    #143200
    cookermann wrote:ive been looking today the reason for overfilling but i couldnt found out why
    Multi function tablets will usually do it quite nicely……… excess froth.
    realengineer
    o no
    i use just 7 grans of powder and a good rins aid
    beeing fine for 3 years
    bernstein dw just a lot of c………
    thanks for replying but i am an engineer and it
    hurt me to have to give up on me own dw
    damn sortingeveryone dw wm cooker etc and not even able to sort me own
    i tel u lifes a bitch
    and i am alive
    said by a belgium engineer lost in great britain
    sorry england
    #143202
    Cheer up – just bear in mind that it’s a cheap Chinese dishwasher and all the fixing in the world ain’t going to make it a better one 😀 .
    We were Belgians – 150 years ago apparently!
    :p45:
    #143203
    Dales-Electronic
    You don’t look that old Chris !!
    #143204
    realengineer
    o yes fixed the dishwasher
    repair connector block to controller
    just a bit burnt out
    turnt the contacts over and cleaned the boardand off whe go
    not bad for anold belgium lost in uk
