Re: Bernstein cooker fault
Hi there
To test to see if the heater has blown, first turn the mains power off or by there fuse box(fuse box would be better)
you will need a multimeter and set it to ohms, open the back panel and disconnect the 2 leads going to the grill and put the multimeter leads on the grill connections, if you get a reading then the grill is working but if you get no reading or a reading that jumps around then you will need to replace the grill element.
