best machine
  • #47067
    daza1
    Hi. Any advise on the best of these two. Hoover Vision HD 8kg load 1400 spin. Or Candy Grand 8kg load 1400 spin. They are both reconditioned machines. Thanks. Daza
    #292202
    Re: best machine
    Same low end product…, 😥 not very good new never mind reconditioned, basically same machine, made by Candy. :rolls:
    #292203
    helo_75
    exactly the same machine
    save your money and buy summert proper
    #292204
    daza1
    Re: best machine
    Thanks for that. Can you recommend one thats good. Family of 4, loads of washing. Need one that can easily be serviced with split drum for bearings etc. Quick wash would be good? Rather get an opinion from here than from all the blurby salesmen that dont know …anything.
    Correct spellings on this one 😳
    #292205
    helo_75
    not many with split tubs, and deffo not the hoover
    u need be lookin at a bosch to be honest
    #292206
    Re: best machine
    Quick wash is not something you should want to use that often.
    Smells
    Quick wash
    Also best to stick to a 6kg max load.
    Large loads
    What is your budget?
    #292207
    Alanj
    Re: best machine
    daza 1
    buy yourself an ISE AW23. You won’t regret it 😛
    Alan
    #292208
    Alanj
    Re: best machine
    Daza 1
    if you go to the ISE website, http://www.iseappliances.co.uk or find the link on this site, you can find out where your nearest supplier is.You can also download a brochure in pdf format for your information. 😀
    Alan
    #292209
    daza1
    Re: best machine
    NO budget really as long as it lasts like it should.
    #292210
    Re: best machine
    ISE or mid to high end Bosch it is then. 🙂
    You need to lay out at least £400 to £450 to get anything half decent TBH.
    I have to replace the main bearings in a Bosch that is just over 2 years old later this week but it is one of the Spanish made, sub £350 appliances. :rolls:
    #292211
    Re: best machine
    If budget is not a consideration, ISE10 every time.
    The only viable option to that is a Miele, but not the cheap ones.
    They are both in a different league to most anything else.
    The ISE doesn’t have some of the “fancy” features that the Miele does but that’s as much of a disadvantage as it is an advantage, depending on what you want or need. The ISE is simple to use, durable and just ludicrously well built as well as sustainable. It is what it is and doesn’t pretend to be anything else but that.
    The Miele tends to have add-ons like (what I consider) silly things like stain busters and 20 levels of spin speed or whatever, basically, stuff that looks good on paper that most people will rarely, if ever, use.
    Beyond that I’m not going to slag Miele off, I’ve resolved to try and not do that… for at least a week. 😉
