which kit do you find the best value?
buying separately each component of the drum running gear is expensive, so which would work out the best value for me where for example i usually use 4 bearer pads, a belt and a square or teardrop bearing. everything else is generally ok. to not replace either the bearer pads or bearing is in my mind somewhat megligent if they show wear, but if i bought them separately they work out far too expensive for a customer to want to go ahead with the repair.
