bf1620 hotpoint
Viewing 15 posts - 1 through 15 (of 27 total)
  • #37023
    fasetester
    hi guys have to look at a hotpoint intergrated dishwasher. modelBF1620 any pointer would be helpful when program is selected say number 2 the light goes back on to number 1 and flashes on off on off the said it was very little used thanks fasetester.
    #253156
    timdowning
    Re: bf1620 hotpoint
    Do a search using BFI620. Might point you in the right direction. 😉
    #253157
    Re: bf1620 hotpoint
    HERE – p2, Known Error Codes. LED1 flashing – leak into base.
    fasetester
    Re: bf1620 hotpoint
    thanks chris do these suffer from the 3 and one tablet fault. and opening the door during wash over spill. went to check out dishwasher base flooded dryed base seemed to be going ok told the woman to try it for a few days and see how it goes. what are the main points to leak on this dishwasher. thanks fasetester.
    #253159
    fasetester
    Re: bf1620 hotpoint
    hi guys have to look at this dishwasher again any pointers on known leakage spots. she said it done a cycle but it took longer that usal. then the next time she put it on reverated back to flashing first light on the left thanks. fasetester
    #253160
    fasetester
    Re: bf1620 hotpoint
    any one do the have a known leakage point. thanks fasetester 🙂
    #253161
    Re: bf1620 hotpoint
    Most of us spend the time and observe what the machine actually does…..
    Standard leaks…….. Circ pump. Overflow turret. Early versions had dribble tubes at the front of the tub. Distorted tub front causing the bottom door seal to fall off. Knackered bottom door seal anyway. Spilt bottom rotor. Top door latch loop not pulling door fully home. Twist fit pump “O” ring leaking. Mice eating drain hose. Choked pressure switch chamber. Water in pressure switch. Water in pressure switch hose. Pin hole in tub base. Jammed rotors spraying water into the door seal rather than rotating. Oh – 3-in-1 tablets. Seen ’em all…..
    Take your pick……….
    Re: bf1620 hotpoint
    Not forgetting the weepy fill hose dribbling down the back panel.
    fasetester
    Re: bf1620 hotpoint
    thanks chris for your reply. dont think it is coming from the door if the pump is leaking can the o ring be replaced on its own. no water on the floor just in the base. any that i went to so far with flooded base never had to go back. went ok after the base was dried if it is a choked pressure chamber or what is a overflow turrent does it over flow when their is a blockage in the i w m s or tranfare pipes and if the main washer pump is leaking is there a seal kit for it thanks fasetester 🙂
    #253164
    Re: bf1620 hotpoint
    Hi Fasetester
    It would be a good idea to go to the call,Take the panels off,dry out the base,then Get the customer to make you a nice cup of tea or coffee and take a seat on the floor and watch for the next 30-45 mins to see where the water is coming from.Then take the nessesary action by repairing or replacing that part.
    If you check through spares availablility with your spares suppliers they will be able to let you know if they hold seal or repair kits in stock,But in all honesty if the seals have gone then quote and replace the whole unit.
    Bryan
    #253165
    fasetester
    Re: bf1620 hotpoint
    thanks guys went back to dishwasher pipe that feeds top basket leaking. treads broke away from the pipe does the seals come with this pipe. the one on the big white nut where the basket pushes into looks a bit worn and the bottom connection that is connected to the heater is one of the crimp type hose clips can the be reused or would a screw type hose clip do fasetester. 🙂
    #253166
    Re: bf1620 hotpoint
    Top Spray Feed Pipe Assembly = C00094152
    #253167
    fasetester
    Re: bf1620 hotpoint
    thanks martin for the reply does it come with seal and new hose clip. or would a standard screw hose clip do. do you need a special tool for the crimp hose clip. fasetester.
    #253168
    Re: bf1620 hotpoint
    Hi Fasetester
    Could you asnwer this quick question ?
    how long have you been repairing domestic appliances ?
    Bryan
    #253169
    fasetester
    Re: bf1620 hotpoint
    i though that was what this forum was set up for helping engineers out. is their only a certain type of question that can be asked. i think you have a attitude problum r600a we cant all be know it all can we mr fridge man fasetester 😉
