BFI62 Fault, 2 Middle Lights flashing
Home Forums Public Support Forums Help And Support Dishwasher Help Forum BFI62 Fault, 2 Middle Lights flashing
  • #30401
    stehgt
    Ive got a Hotpoint BFI62 about a week ago it stopped working it would try to run for about 10 seconds, then stop and beep once. It would then lock up and you had to reset it. I pulled it out yesterday (not really knowing what im looking for) and cleaned out the waste pipe as it was really full.. I put it back and it appeared to start working. But i can hear like a buzzing noise for the 1st minute or two like its trying to pump something but then it starts. After about 5-10 minutes it now stops and contantly beeps for about a minute. I open the door and it reports 2 middle lights flashing. Any ideas???
    Thanks alot
    #227047
    Re: BFI62 Fault, 2 Middle Lights flashing
    Initial buzzing noise will be the drain pump running. The two flashing lights mean that the machine has not detected a fill with water in the time allowed. Water may be off, fill hose trapped or kinked, inlet valve may have failed or possibly a PCB fault.
    Power off before removing any panel.
